MEGA DVD with photo mug templates and other frames ;) 50% off
Lee
Re: MEGA DVD with photo mug templates and other frames ;) 50% off
Post by Lee »
it was just a couple of non0complex ones, I thought you put them together using different elements.....Im not sure how cost effective a 'designer' would be though......
if you have idea what you want on them then designerdraw everything in corel. then convert it all in ps. this is how most of them was done.
JSR
Post by JSR »
TPM
If you want to use pre-existing elements that are in some of Paul's templates, then it's easy enough to modify them yourself. Just buy the ones you want and start tweaking.
This is what I did with the Christmas ones the other year. I bought a bunch of them and then moved elements around while resizing to suit my standard print size. It's a doddle.
Doing this also makes your particular template different to everyone else who bought the same ones.
David B
Post by David B »
Hi Paul
Mine arrived today. Just had a quick look and very pleased. Thanks
David
Lee
Post by Lee »
ahhh good thinking :-))))
David B;25783 wrote:MEGA DVD with photo mug templates and other frames ;) 50% off
Hi Paul
David
Good stuff!
hope you like it ;)
