need help
Re: need help
none of the software can use jpeg to cut. only when you trace it manualy as a layer but this is not the jpg any more
Re: need help
I design in corel, convert to curves and "send to" signcut, my cutting software and then click cut, simples
Re: need help
I use Corel as well but have a plug in so can cut direct from Corel without having to go into other software.
Re: need help
I had the coreldraw plugin but couldn't get away with it having to put an outline on everything all the time.
- mrs maggot
Re: need help
i use corel but cut in signblazer
