John G;23723 wrote:
I used to dunk but as Paul said, they ping a little - and that cannot be good for the mug.
and it can not be good for the person who got hot tea in it
John,John G;23723 wrote:Where your mugs from?
I don't dunk - I put a fan on the work bench set to cool and just place the mug in front of it after taking the paper off. By the time the next mug is ready the first ones cold.
Paul;23725 wrote:and it can not be good for the person who got hot tea in itif fall in bits in somone elese hands
Mrs Maggot (really?), Interesting use of a teflon sheet. Do you tape it over the sublim sheet, or attach it in some way to the heat blanket? Davemrs maggot;23965 wrote:i had one bleed at the weekend, i had a good look at it, and then noticed the teflon sheet i have between the press and the mug had a crease in it - sorted.
i dunk, but will be trying the fan method, as i like the "cool idea"
Paul,Paul;23730 wrote:Nash. I am saying IF you got that ping noize then you may have a complain. not only coz you dunk them. I did it too.
Dave. I had a mugs from coralgraph, BMS, subli-nation and some other from ebay. they all ping
