Hope this works
It is a picture I have just taken showing the TS switch.
You will note i have the dials on just over 2 and that does a cup every minite when I am using the two wraps.
Realistically though I dont rush the adding the paper and taping.
Plus they get hot!
Hope this helps
Mug wraps
Re: Mug wraps
- vB_ID:293
- 003.jpg (101.88 KiB) Viewed 106 times
- 003.jpg (102.23 KiB) Viewed 106 times
Re: Mug wraps
Thanks Tony, I'll get an email off to TMT.
John
John
Re: Mug wraps
Hi John, just wondering if you found out about the different models of TMT mug presses? re:Laser transfer/sublimation..
I have just purchased a second hand TNT HTP616 plus, which also has no T/S function, prior to reading this thread...dohh!
I was considering sublimation over laser transfers for printing mugs as most of the posts I have read on the subject seem to say the finished product from the laser
transfer is not as good as the sublimation print.
Shirt Printing Design and Culture teesandhoodies.com
