B1100 Ink problem
Re: B1100 Ink problem
Hi
I've went to print some work off this morning using my B1100 and the colours are not coming out it is just all coming out a light grey colour.
Any idea's? i've done 4 head cleans and it's just getting worse, don't want to do more incase i flood it.
Matthew
Try doing a couple of test prints using direct colour Matthew, it might help unblock it:
http://inkjetprinterhelp.us/Color0.gif
I know you may think it won't work but leaving it an hour (if youve got that long) after head cleans also helps.
That's if it is a blockage at the print head and not a twisted/blocked tube?
Cheers Adam i'll try that in a bit.
Just done the syringe thing in top of cartridge that it says on BMS website and now i'm not get anything paper is coming out blank
Matthew
Just done one head clean then printed the image you attached and it's worked fine (fingers crossed stays that way).
Thanks alot Adam i appreciate it
Matthew
Hi
I'm getting really fed up now thought i sorted it yesterday, but now one of the blacks is not working and coming through with lines so i did one head clean and then nozel check and now all the colours have lines through.
Can anyone help before i throw this printer out the window?
Matthew
It's funny Matthew 'cause I was going to post a reply last night.
At about 8pm I too had problems with my B1100 and it took me about an hour and half to get it sorted (must be a day for the B1100's!).
I didn't so much keep cleaning it but I printed various images with colours in to release the blockage - it eventually worked
Hi AdamAdamB;23244 wrote:It's funny Matthew 'cause I was going to post a reply last night.
It must of been bad day for Epsons lol, glad you sorted it though as i know how stressful it is.
I've left it for now, i'll try printing few images later see what happens, it's also displaying very low ink levels on printer screen not sure if this means anything?
Matthew
AdamB;23244 wrote: (must be a day for the B1100's!).
nope
Ink levels will reset automatically so that doesn't mean anything. If you're having continued problems have a look at our FAQ on this... Print quality has deteriorated...Alligiftor;23245 wrote:Hi Adam
http://www.printerowners.co.uk/faq/12/1/sublimation-advanced.htm
