Problem with blue ink on D120 printer
Re: Problem with blue ink on D120 printer
We have a bulk feed system using the Epson D120 printer. We are having problems with our blue ink. When we do a nozzle check the blue isn't being printed correctly, lots of gaps. We have cleaned the head, tried conventional ink which works ok, and taken out air from the cartridge by syringe.
Some blue is getting through, but our images on the mugs are coming out very purple, for example, the sky is purple and our customer has supplied us with some images of "sky Blue" iris's which are now purple!!. We have tried adjusting the amount of magenta and although slightly better, it is nowhere near the colour it should be.
Can any one help us...please ?
Have you looked at our FAQ on this matter...
http://www.printerowners.co.uk/faq/12/1/sublimation-advanced.htm
Do you get a perfect nozzle check pattern? There's no point in going to print if you don't get that.
The cyan doesn't give a good nozzle check, all of the other colours are perfect, but hardly any blue is coming through on the check.
With the original "normal" cartridges the Cyan is perfect.
Can you let us know how you get on with the other things to do as explained on the FAQ? The problem sounds as though it is in the EasyFlow system...
I have tried everything on the Faq, I retried a nozzle check this morning, firstly using Original cartridges, the black, magenta and yellow were all fine but the blue had huge gaps in it, I headcleaned and reprinted the nozzle checks 3 times, no difference with the blue, I then left the printer for a while and retried the nozzle check with the Easy flow system, exactly the same result. I am now guessing that the problem lies with my printer. My dilema now, is that I have spent alot of money this week on more ink for the free flow system, so I need to continue with this system, but is it only compatible with a D120 and if so, how widely available are these printers now ?
If you can't get a good nozzle check pattern with the original cartridges then this has to be resolved first. There are some posts on here about head cleaning which might be worth a look at. The D120 was discontinued some time ago, so it's unlikely that you'll find a new one.
Just an update. I have managed to buy another D120 printer, (very lucky to find one!!).
The nozzle check is brilliant on all colours, no gaps.......but, the sky blue colours on the mug are still coming out purple!!. The blue on the nozzle check is coming out the correct colour.
What are our next solutions.
I had this problem with my Ricoh, and purple was coming out royal blue, I had switched on the ICC profile along with the powerdriver, switched off the ICC profile and it worked fine
Need to know what graphics package you are printing from and some idea of your printer settings and ICC profile settings to help further. Have you set everything up as per the instructions for using the ink from your supplier?penpoul;22523 wrote:Just an update. I have managed to buy another D120 printer, (very lucky to find one!!).
