help geo knight Heeeeeeeelp
Re: help geo knight Heeeeeeeelp
I have a Geo knight mug press, it has not been used for at least 9 months, my husband has forgotten how he used it, I have never used it, so if someone could guide me through on what to do and how to use it and timings . the mugs I will use I have brought from Martin, his European mugs. He also said it need adjusting as it was a little bit loose. Any help or advice you can give would be most appreciated, I have never used a mug press and I will be using it in the shop with no assistance from the husband, I've put it off long enough as you can see by the time it was last used
Yeepee it is, had a look at the link and it the same as mine, does any one know is it has any peculiarities, the one thing I do know reading the manual is not the same as using it. The manual are always to in-depth, we have just struggled with a cap frame, it took four hours just to get it on, we made hard work of it, now it a 8 min job.lol thank you by the way, nearly forgot so excited
See small things can make you happy, thank both, this means I can learn my way and at my pace.
I've just started using a mug press after using a mug oven previously
I wish I'd switched over years ago - much more convenient.
Mark
Mark
