I've been using the laser printable vinyl from Magic Touch with good results.
Print on laser printer, then heat laminate with 'coverseal' (also from MT), then cut on robo cutter, peel off excess vinyl and sell it! Coverseal gives a flexible, slightly textured finish if using the application foam (comes in the box)
I have stickers outside on the windows of a landrover and colour is the same as when printed 2 years or more ago, no sign of coming off (gets hit with the pressure washer - not all that often mind:) Same sticker on a box inside so colour comparison is easy.
I understand that special inks can be used on more expensive printer/cutters for a pro finish, but as others have said a big setup. The ones I've been doing have been well recieved over the years.
BMS supply all the Magic Touch stuff as others may well do.
DJ
printer suitable for printing onto vinyl
