Anyone used a jig before?
Re: Anyone used a jig before?
I don't really do enough coasters at the moment to justify this but wondered out of interest if anyone used a jig?
That's a good idea, I haven't done any coasters apart from 2 samples I had - but this makes it look very easy. Where's my router
She never mentioned nothing about template. you need this to print properly. but i preasume it comes with the jig...
The template can be easily knocked up in coreldraw etc - just think its a quick and easy way to do the coasters
I guess once it's set up that's it. I wonder about bleed on an all over design though.
well... oncei spend just over hour to do keyring inserts tempalte
so if you have to do it youself then is not as quick as they say
but i agree. if they give your template you can print them in bulk in few minutes.
Sounds like a good idea if there was a jig for non-UniSub coasters. I've occasionally done large orders of coasters, and a jig would have been useful on those occasions.
I'd bet that if a jig was available, it'd be prohibitively expensive.
