Charlies Angels Font & Bubble Font....
Re: Charlies Angels Font & Bubble Font....
Hopwfully this is bigger..
[ATTACH]182[/ATTACH]
- vB_ID:182
- Untitled-1 copy.jpg (17.99 KiB) Viewed 313 times
- Untitled-1 copy.jpg (18.04 KiB) Viewed 313 times
ahhh, it zooms in !
Well, this is the font I, trying to create, including the fire if poss!!!!!!
If anyone has come across this before....
The fire would have been added as an aftertouch mate through photoshop or coreldraw.
Use the font to create the wording required then use this as a template when placing a fire background below, then cut away everything on the outside of the wording you have, delete the wording and then you should have the fire in the shape of the wording you require.
I think I may have confused matters with this ............... hope not?
hmmmm.....okayyyyyyyyy.... I thought there would be a font that I could "fill" with fire....!!! Better go and scratch my bonce and think about this one....!!!
Thanks Adam!
Thanks Adam!
i'd say it's quite easy to make though as Adam says use coral or PS etc
Ive just tried PS got som efire effect but couldnt seem to get right.... will try again!
is this what your trying to do
[ATTACH=CONFIG]183[/ATTACH]
- vB_ID:183
- flame.jpg (45.73 KiB) Viewed 313 times
- flame.jpg (45.83 KiB) Viewed 313 times
wrong text style i know but fairly easy to do
http://www.photoshopessentials.com/phot ... e-in-text/
that with an outline would be greaaaaat! I'll try this link!
