FlexiSign Pro - Adding Easy Weed lines
Re: FlexiSign Pro - Adding Easy Weed lines
Anyone using FlexiSIGN? I wondered if it was possible to add easy weed lines across the design when cutting.
Thought I could see in options where to add it but it hasn't worked. Is it Easyweed?
I use flexiStarter. and yes :) its called easyweed.
Should you be able to see the easyweed lines in the preview? I have ticked horiz & vert lines and can only see horiz lines. Put a tick in easyweed and nothing looks different Paul.
I'm wondering if the particular design I have will only work with horiz lines. Used this feature on other software before and it filled in the background with lines at a set distance.
I thought this same :) nothing in the preview window but they are cutted. make sure you dont use them for small letters :)
Aha, just put a simple design in with space around each letter. I can now see the lines, so it only draws inbetween the design/letters, it doesn't put lines across the design?
I dont remember mate as I dont use this option any more :( but remember it was very helpful :)
