printing problem
beabea1
Re: printing problem
Post by beabea1 »
can anyone help when printing ink is bleeding or coming out dull the printer is the epson p50
Will need a bit more information here to help. What inks, what printing media (paper or something else?)
beabea1
Post by beabea1 »
hi new to all this the printer is epson p50. ink is sublimasion ink. paper is sublimasion when printing the print comes out with to much ink and runny.have cleen the heads when i have don this prints great and then it gos runny any help would be great
beabea1;19405 wrote:hi new to all this the printer is epson p50. ink is sublimasion ink. paper is sublimasion when printing the print comes out with to much ink and runny.have cleen the heads when i have don this prints great and then it gos runny any help would be great
As the P50 isn't a supported sublimation printer then can I assume you're using a third party sublimation ink or is it a Sawgrass sublimation ink?
if is to much ink on paper then just please tell me you dont hold your ciss above your printer??? also you say is dull. is it dull on paper or after you press it on blank?
Where did you buy the setup from? Have you been back in touch with them for support yet?
beabea1
Post by beabea1 »
ha no did not hold ciss above printer ?? o yes i am blonde ha ha yes is dull on paper not go to printing on mugs only just got com set up and trying to set printer up new to sublimastion
:D you need to press it first to see the effect. print on paper is always dull :D
beabea1
Post by beabea1 »
hi kids got me the printer and the ink and mug and othere bit thay got was from dsf so i now it is not the ink or the mugs think the prob is with the printer got the ciss from the internet
beabea1
Post by beabea1 »
sorry got the ink mugs anf othere stuff from dsf
