Not having a good day...
Re: Not having a good day...
Just started a decent sized order, that wiill have ongoing orders. I'm 5 hoodies into it and my heat press has died....
I was saving for a new cutter now this happens....
At least I still have enough time to replace it and fulfill the order.
What make ofpress is it? May be able to get it fixed, won't help you straight away but if you do get another press you could then sell this on. Otherwise, could someone help you out with orders until it's fixed maybe?
I think it's a lovecut not 100% sure as I got it from second hand from ebay.
I was planning to change it eventually at some point anyway so I guess I'll just bite the bullet, I have a plenty of time to get a new press and finish the order. I think it's maybe the thermostat, it turns on, the timer works when its closed but it doesn't get hot but both fuses are ok.
No big deal I guess, just a pain as I had been up till late getting everything ready & cut for a pressing session.
if this is lovecut and is less then 12mc old you is still covered with warranty
why not? is there any law about this?
Well yes - your contract is with the the ebayer - not lovecut and the ebayer never gave a years guarantee
alright...
Buying second hand and its a chance you take - found this on tinternet - 3rd paragraph down:
http://whatconsumer.co.uk/second-hand/
