Round Coasters
Re: Round Coasters
I'm looking for a few round coasters (like the ones BMS sell, http://www.printerowners.co.uk/sublimat ... asters.htm but circle-shape).
I don't want to buy in a load until I'm sure if the order grows as it should. I've checked BMS, Coralgraph, Subli-Supplies, ETC Supplies, Sublicut, even ebay, but no one seems to want to sell them.
I know Listawood do them, but I'm still waiting for them to send me a username/password so I can log into their website. (I'm also a bit hesitant to spend £6.40+VAT on postage for a couple of coasters.)
Has anyone got any they can spare? Thanks.
Re: Round Coasters
Ian M;18664 wrote:Jonathan, how about Xpres http://www.xpres.co.uk/shoppingcart/aca ... sters.html
I was looking at these too Ian - have you used them? Any good?
Re: Round Coasters
They're Unisub so good quality.
JSR, I have quite a bit of stock if you need any.
Re: Round Coasters
Andrew;18686 wrote:They're Unisub so good quality.
Hi Andrew
What size are the ones you have? Unisub ones are usually a bit larger (and a bit more expensive) than normal ones and I just need to be sure that the customer's getting what he thinks he's getting.
Thanks!
Re: Round Coasters
Thanks Ian, but Xpres' minimum quantity seems to be 40. Once I'm sure the customer will be ordering more, I will be okay with stocking up on them but, for now, I just need a few.Ian M;18664 wrote:Jonathan, how about Xpres http://www.xpres.co.uk/shoppingcart/aca ... sters.html
If it comes to it, I'll do a mixed order with Listawood. Their minimum quantity is 10, but I'd rather not place a large order even for mixed goods right now as I've just been stocking up from other suppliers and the funds are running low.
Re: Round Coasters
Mine are 9cm and the same as Xpres. Unisub will make them whatever size the supplier asks them to as long as you get a high enough quantity. I'll get one in the post to you if you like. You can have how ever you many you want at the same equivalent cost as Xpres 40 box (48p + vat each). Delivery by whichever is the cheapest method.
Re: Round Coasters
No I haven't Barry but always found Xpress products to be always very good quality & very friendly service too.barryslip;18685 wrote:I was looking at these too Ian - have you used them? Any good?
Re: Round Coasters
Andrew;18699 wrote:Mine are 9cm and the same as Xpres. Unisub will make them whatever size the supplier asks them to as long as you get a high enough quantity. I'll get one in the post to you if you like. You can have how ever you many you want at the same equivalent cost as Xpres 40 box (48p + vat each). Delivery by whichever is the cheapest method.
9cm sounds like the right size. Thanks, Andrew.
I could do with about half a dozen or so. The customer only wants 4 for the moment, but he may go for a larger order later.
