sublimation stickers from BMs
Re: sublimation stickers from BMs
The white sublimation sticker/ vinyl will stick to cars that's not a problem, although it's not the same as sign vinyl. Any sublimation print won't withstand UV light permanently so it will start to fade over time (possibly a year or so). If I was doing this for a car I would be inclined to print the sublimation vinyl and fix this to something like the magnetic sheets so that it can be removed rather than stuck permanently to a car.
What would you use the white sblimation sticker/vinyl for, stickers for...
