Sublimation Slates - anywhere in the UK?
Re: Sublimation Slates - anywhere in the UK?
http://www.printerowners.co.uk/sublimat ... -wraps.htm
Any heat proof rubber will do just get the correct thickness for what you need. The thicker, the longer to transfer the heat.
sort off. My is without texture. 100% flat and biger. £9 delivered.
I just picked two sheets at Asda's in case anyone is looking for them in places?
They were £5 each or two for £8 ................. bonus!
kool we'll be popping in there on fri eve so i'll grab a couple
So,
I just pressed one of these slates and wasn't too impressed, but perhaps due to covering it with a silcon mat the temp maybe needs to be upped 10 degrees?
I will try another later with the temp up 10 then post photos if anyone is interested?
Yes please Adam
I've not had a chance to do mine yet as I Don't have a silicon or similar type sheet to put on top of it
I've just done another one and put the temp up to 205 degress and pressed for 7mins - a vast improvement!
I will post images later ..............
waiting for pics mate! Cant do my yet as iam waiting for my silicon too...
