D120 printing problems
dazza8087
Re: D120 printing problems
Post by dazza8087 »
I have a D120 with bulk feed but i can not get it to draw ink ive tried drawing ink through but still not working any clues please
is this forst connection of ciss to this printer?
dazza8087
Post by dazza8087 »
had this printer for 6 months now
all colors? or only one wont work? any air in the tubes? rubber bangs removed and replaced with air filters?
smitch6
Post by smitch6 »
my ciss on my S21 was a git to get working
it took ages to get the air bubbles out of the carts
but once i did it then worked fine :)
keep using the syringe (on the carts not on you lol)
and hopefully it will work as long as everything is set up right
dazza8087
Post by dazza8087 »
was working fine now black and blue not working tried and tried using syringe
smitch6
Post by smitch6 »
i left mine for a few hours slightly higher than the printer that way the bubbles will rise
BUT...........
beware and keep an eye on it as ink will fall and will spill all over the printer if your not careful :)
the other thing i did was remove the carts and take the needle off the syringe and draw it through the actual cart hole in the bottom
hope that makes sense
i found that helped more than anything
i saw the youtube vid on ebay somewhere
smitch6
Post by smitch6 »
what happens with it being intermediate like that is if you are pumping ink into the cart or removing air ink gets near the right point and works for a while
but there is still air in there so after a short while or the next day it stops again
i sympathise mate its really annoying but once properly sorted it shouldn't happen as long as you don't run out of ink
dazza8087
Post by dazza8087 »
only problem is now getting low on black ink got orders to do and now looks like i cant do them
dazza8087
Post by dazza8087 »
still can't get it to work tried till early hours and tried again this morning
