Yellowing on Subli Tee
Been thanked: 12 times
Re: Yellowing on Subli Tee
Just printed a subli tee and got a yellow haze around a couple of the edges. Initially thought it looked like a scorch mark so checked the press and did a few more test prints. Markings appear to be in the same place every time I print. (Even if I resize the print)
I printed on another printer and the marks didn't appear. This should isolate the problem to my first printer so I'm wondering if this could be over spray on the yellow?
Checked all the other usual possibilities but I'm pretty much sure it's something to do with the actual printer. Even tried 2 different papers as I was testing my own 'hint & tip' of tearing the edges to get rid of the paper mark (which bloody well worked as well!)
jennywren
Post by jennywren »
When I have marks that I can't see and can't find the fault. I have often found it I check the image in photo shop and go into layer style and use the stroke and I am have on a few occasions found marks that I can not see but the stroke show it up, its worth a try. Hope this makes sense
Gordon
Post by Gordon »
Hi I have the same prob with Mug's. never thought it was my printer but my mug press/paper.?
have you had to same?.
Not seen it on anything else but tbh not used the 1400 much since this happened, need to do some more tests
smitch6
Post by smitch6 »
Hi gordon glad to see a fellow Norfolk member ;)
Gordon
Post by Gordon »
Hi smitch6, thank you, I was a member before, back in Aug 10, but to be honest, well the new site is much better for me, I'm in Cromer where would you be?, ;)
Gordon
Post by Gordon »
can you tell me how to upload a pic please?
thanks gordon.
smitch6
Post by smitch6 »
you need to go advanced then upload it to the server then insert it in-line lol
its a little complicated but once you've done it a few times its easy
i'm south norfolk near beccles, and actually at waveney river centre :)
Or, just click on the insert image in the quick reply box.
smitch6
Post by smitch6 »
well i never knew that was there rofl
you learn sumthing new every day lol
Users browsing this forum: Google [Bot] and 9 guests
