B1100 wont print
foleygifts
Re: B1100 wont print
Post by foleygifts »
please help i'm just starting to use my new printer,B1100, i am new to all this.
the Artanium uv+ inks are installed and tried my first test print nothing came out.
tried nozzle checks/head cleaning but it doesn't print anything not pattens for the nozzle checks either.
i'm very worried this has cost me a lot of money and getting really stressed out.
please help! is it something simple or major?
Katie
New to sublimation
Kaz
Post by Kaz »
Silly question, but have you got it connected to your PC and plugged in and the drivers installed?
foleygifts
hi yes connected,installed and plugged in...
Katie
New to sublimation
did you took your rubber bungs out of the cis bottles and replaced them with air filters???
foleygifts
i have refillable carts would it apply to them aswell.
with having 2 kids cis would end up on the floor so played it safe.
really gutted!
Katie
New to sublimation
I would quickly put in the original carts to make sure the printer is fine (should be, but worth checking). If this prints fine then the issue can only be with the refillable carts. Have you filled these yourself or got them from a company that has pre-filled them. Are these the genuine two part Sawgrass refillables or from a third party? On refillables, have you removed the tape to allow air back into the cartridge (should be a removable strip on the top of the cart or something similar).
foleygifts
Paul;17287 wrote:did you took your rubber bungs out of the cis bottles and replaced them with air filters???
should i have taken one of the plugs off the top of carts?
Katie
New to sublimation
yes
take them out. you need a vacom to ink flaw.
foleygifts
hi,
i no longer have the originals ~(silly me i know) sold to raise more funds.
i'll remove one of the plugs and do another nozzle check to see what happens.
Katie
New to sublimation
no "one of those" just correct ones :) those for reffilling need to takin out ;)
