Mug heat tape.
bikertec
Re: Mug heat tape.
Post by bikertec »
Just a quickie why do all the demos show using 4 pieces of tape for mugs when its easier to use only 2 longer strips. Does it make a difference.
Ride it like you stole it shiny side up.
Andrew
Re: Mug heat tape.
Post by Andrew »
Preference I guess. Some just use 1 piece going accross the 2 ends. Can't say I have seen 4 used..
John G
Re: Mug heat tape.
Post by John G »
1 piece, straight through the handle!
smitch6
Re: Mug heat tape.
Post by smitch6 »
i use 2 :)
Re: Mug heat tape.
I find 2 seperate pieces works best for me. You can get away with tiny pieces but I deliberately use way too much as my last employer had a hang up about using too much heat tape....heck a whole roll in just one year? Goodness forbid ;-)
Ian M
Re: Mug heat tape.
Post by Ian M »
bikertec;17143 wrote:Just a quickie why do all the demos show using 4 pieces of tape for mugs when its easier to use only 2 longer strips. Does it make a difference.
Michael, the difference it makes is you tend to have to buy 2 rolls instead of 1.........lol
logobear
Re: Mug heat tape.
Post by logobear »
I find it easier to level with just 2 bits, 2 tiny bits!
smitch6
Re: Mug heat tape.
Post by smitch6 »
2 tiny bits is better for your Profit :) than 4
