Epson B1100 custom profile.
smitch6
Re: Epson B1100 custom profile.
Post by smitch6 »
yes before the colours came out right but the image was grainy
which is why Paul sorted the profile out for me :)
but for some reason i think i've got things set up wrongly somewhere along the line
its a pity i can wipe the whole lot and start again but photoshop will keep my settings so i need to go through everything i think with someone who has a mac, as i think we have slightly dif settings than windows
smitch6
Post by smitch6 »
right i googled resetting photoshop so i followed the instructions
then went thru all the steps Paul explained about setting up the colour settings etc
tried a print out with photoshop handling colours and using the art profile
still came out blue
so i tried letting the printer handling the colours and hey presto the colours were back to how they should be ???????????
weird hey
swimwivsquid
Post by swimwivsquid »
Yep but if it works then use that setting. Strange but if it prints all the time like that then what ho. If you get really stuck with your Mac and need some expert help then Chris at System Solutions is worth contacting. They are based on the Rackheath Industrial Estate and will help with hardware and software. Just say Richard in Grenada mentioned his name. There could be other issues within the OS that he would be aware of. I'm running Tiger on a G4 and you are probably well in front of that. Keep on troshin....
smitch6
Post by smitch6 »
trouble is i'm back to square 1 though which kinda defeats the object of Paul helping me
my images aren't sharp the colours are really grainy they may match but they look rubbish
yes i have a macbook with the latest leopard actually there isn't much dif apart from quicker than the G4
hmmm. i dont know how to help you mate now. as I am sure you double profiling somwhere :( but without actualy see your photoshop I am very limited :( but this icc work. trust me! have you got acess to any old laptop or pc??
ps. just to confirm. you press all images you print do you?
swimwivsquid
Use the unsharp mask filter in the sharpness menu to sharpen your images and is the file that you are trying to print of sufficient resolution? Just trying to cover a few basics.
You are probably already doing this but I just wanted to rule that out.
smitch6
Post by smitch6 »
yes i'm pressing every image paul
and yes the resolution is ok swim
its every image i print out whether its 300 res or 30 res the actual printed image looks the same
colours match but it looks like there's dust everywhere, but obviously there isn't as its a comp image
trust me i'm stumped and very sad as i really want this sorted now
smitch6
Post by smitch6 »
the wife has a windows netbook but it doesn't have photoshop on it
ok. what paper u used again?? also can you post me your graphic. i will press it and see what is like.
smitch6;15975 wrote:the wife has a windows netbook but it doesn't have photoshop on it
you can dpwnload trial just to have a look. so we know if this is because the MAC
smitch6
Post by smitch6 »
yes sure
i am using trupix off BMS
