Rabbit cutter help
Mattie
Re: Rabbit cutter help
Post by Mattie »
Hi
just bought a 53" cutter from a guy but didn't come with driver
It has on screen rabbit and on back the number says 1360 after googling i think it's a HX1360 rabbit cutter but i can't find the driver
Can anyone help i've attached some pics
vB_ID:103
vB_ID:103
vB_ID:102
vB_ID:102
Matthew
Kaz
Post by Kaz »
Which software package are you using for cutting?
If you have FlexiPro, you shouold find the driver in there.
You could try contacting the manufacturers for the driver, if googling for it fails
http://rabbitlaser.en.made-in-china.com ... 1360-.html
Kaz
Post by Kaz »
Just found this, does it help?
http://aspgfx.com/download/rabbit+hx-13 ... +free.html
I clicked the first link and it wanted to install the required driver, afaik
Mattie
Post by Mattie »
Kaz;15946 wrote:Just found this, does it help?
Just clicked link you can only download if you sign up to website
Matthew
Mattie
Post by Mattie »
Kaz;15945 wrote:Which software package are you using for cutting?
Hi Kaz
I'm going to use Artcut 2009 if i can, i've just sent company email to see if i can get driver if not i'm just gonna sell it can't be chewed with it
Matthew
Kaz
Post by Kaz »
Found this site aswell
http://www.eurosystems.lu/index.dml?unt ... prache=eng
Might be better selling ti on if no joy with locating a driver for it.
I had similar problems with my Liyu, couldn't get a driver, but Vista recognised it as being a roland, if memory serves me right.
Reg
Post by Reg »
If artcut 2009 is the same on set up as the 2007 try open manufactors click on others then HPGL or DMPL your cutter should use one of these commands.
