Epson B1100 custom profile.
swimwivsquid
Re: Epson B1100 custom profile.
Post by swimwivsquid »
When you hit print command you get another box that comes up that lists the printer name the presets, print settings, and media Type. Go to Print settings drop down menu and select colour management.Then click on " No colour Management"Set the paper to the type Paul has instucted you to and it should work.
click ther:
then go to your prinetr setings ;)
smitch6
Post by smitch6 »
that setting is just for which printer you want and what size paper
smitch6
Post by smitch6 »
i have tried it with no colour mang and with epson vivid
and tried all dif papers matte, normal etc
i tried phot, best photo
actually i tried every setting possible and the image is still coming out blue instead of black/grey
i made sure all colours are printing and they are the nozzle check didn't have anything missing at all it's perfect
weird hey :~
swimwivsquid
The settings must be the same as Paul has used when he created the profile. Same paper, same ink, same colour management settings etc. Is photoshop seeing the profile.One way to do a quick visual check is to open your image go to View dropdown menu----Proof setup and choose the profile. You will then see on screen(assuming your screen is calibrated) a visual of how your imaage will look when printed. This is not exact but it does give you a good reference point for anything out of the ordinary.You can then adjust your image to how you want it to look when its printed.If you click on Gamut warning in the same menu you will see just how many colours and tones won't reproduce accurately.Have fun...Richard
smitch6
Post by smitch6 »
i tried that and it looks nothing like what being printed lol
i just done the test print paul put up ages ago
and even on that the greys etc are coming out a greeny/blue
smitch6
Post by smitch6 »
when in photoshop 'the assign profile' setting is set as adobe RBG 1998
is that right???
swimwivsquid
Well Paul is the best geezer to help you as he made the profile for you. I use both mac and pc and it should work. Bit of a mystery this one. I take it the other printer you have, printed what you were seeing on screen?
swimwivsquid
smitch6;15957 wrote:when in photoshop 'the assign profile' setting is set as adobe RBG 1998
is that right???
Yes in the colour preferences settings. Not the printer settings.
swimwivsquid
Just checked the view profile settings (on screen) and you need to go to view---proof setup---custom and then choose the newprofile.Its slightly different between PC &Mac at least it is with my version of photoshop (CS2) This will give you a soft proof on screen.Won't affect the printing.
