epson B1100
Ian M
Re: epson B1100
Post by Ian M »
smitch6;15531 wrote:okkkkkkkkkk
so whats a good temp to do T's on then?
my instructions say 150-180 for 20-40 secs
i done the 1st one on 180 for 40 secs and it was still dull
i have a combo press
180-185 degrees for 50-70 seconds but as always you might have to play around those settings to get just what you like.
I think it could be your ink as accdave says.
smitch6
Re: epson B1100
Post by smitch6 »
well the T i made for my wife using it has been washed 4 or 5 times with no problems what so ever its still the same as when i 1st made it
Re: epson B1100
That temp is way too low for sublimation ink. If your supplier is saying 150 degrees for sublimation ink then they don't know what they're talking about. You need 180 degrees minimum for t-shirts. You can go up to 200 degrees but I find the t-shirt can yellow (burn) at that temp. Press at 180 degrees for 60-70 seconds and you should have vibrant colourful results.
Those temp/ times sound more like ink transfers, not sublimation ink...
smitch6
Re: epson B1100
Post by smitch6 »
yes i just had a play :)
good stuff that cheap material off ebay init
done 1 at 180 for 60 secs turned out better but still not right
so i turned the press up to 190c for 60 secs and wow :O
it looks brill
so thats the colours sorted for now until i get some better ink lol
so to answer Paul yes that test pic comes out gorgeous :D
smitch6
Re: epson B1100
Post by smitch6 »
thanks for your help again folks :)
it is so handy havin this place for support
smitch6
Re: epson B1100
Post by smitch6 »
i just done a test print with that image on a waste mug and yes its come out grainy
all the colours look nice and the skin tones are right esp the lil babies etc
but all the colours are grainy
so i guess it really does look like i'm going to have to invest in some better ink
look out card your gonna get used again :(
JSR
Re: epson B1100
Post by JSR »
smitch6;15543 wrote:i just done a test print with that image on a waste mug and yes its come out grainy
What paper setting are you using in your printer driver? I find I get grainy images if the printer driver is set to print to "plain paper", but if I change it to "matte paper" then the quality is significantly better. It's slower to print, but the quality more than makes up for it.
If you're currently using "plain paper" setting, it may be worth trying the better quality paper settings.
smitch6
Re: epson B1100
Post by smitch6 »
yes it is set to plain
i print out using photo settings tho
i'll have a play with the matte settings tom
JSR
Re: epson B1100
Post by JSR »
smitch6;15550 wrote:yes it is set to plain
If it's set to "plain paper", the printer thinks it can't lay down as much ink as it would on "matte" paper (because plain paper saturates too quickly). Transfer paper is coated on one side just like matte paper, so it can take more ink. I think you'll find an improvement.
smitch6
Re: epson B1100
Post by smitch6 »
oh right ok thanks i'll give it a try tom
