JNMann wrote:May be worth starting off with refillable cart's until you're doing more work. A bit fiddly to start with but cheaper than buying a CIS and also less prone to problems with air blockages in lines etc.
If you do this make sure you get decent carts though. My first lot split at the edges, luckily whilst out of the printer. The ones I'm using now are working perfectly, fingers crossed.
Hi Justin,
I had a whole lot more problems with refillable carts than I have had with my C.I.S.S. My cartridges split too, when I threw them across my shop
The theory I came up with is that when you need to remove the carts to fool the printer that you have changed them(this is what I had to do with mine anyway!) when you put the carts back in you force air into the print head.
In theory, if you keep your C.I.S.S system topped up correctly air should never get in as it is a sealed system.
I have had a very embarrassing experience with a C.I.S.S system before, which was etirely my fault but I will save this yarn for another day
Phil
