Are those 3d vaccum sublimation ovens good for mugs
mark25810
Re: Are those 3d vaccum sublimation ovens good for mugs
Post by mark25810 »
Hi there so i have tried over the years endless amounts of mug and tumbler press machines inc things like htvront auto etc
And i end up having issues with more mugs than not
I usually do full wrap designs and find often one of more areas where theres a smudge or some issue. I tape well and tight, tried silicone wraps tried everything and its pot luck if a mug comes out perfect
Are the 3d sublimation ovens where you can buy those usually bright lime green suction silicone molds anygood. Where you plug the tube into and it vaccum sucks all the air out
Chad
Post by Chad »
No experience with 3D vacuum ovens for mugs, however I use a conventional fan oven with silicone wraps and get great results! Image
