Nysfou ink?
Re: Nysfou ink?
Hi. I haven' been sublimating long and have an Epson ET-14000, which has been brilliant. Knowing less than nothing when I started (and probably not much more now!) I bought sublimation paper and a set of Nysfou inks from Amazon. Luckily, both have also been amazing, even without applying an ICC profile. Now it appears that the Nysfou sub inks have gone off the market. Does anyone happen to know please what brand of inks Nysfou badged as their own? One of my black tanks is very low, but the others are still about half-full - can I just top up with another brand as the tanks are used up?
Re: Nysfou ink?
If you want cheap ink which is readily available, you should consider moving to InkTec Sublinova, as lots of dealers sell/resell it.
Re: Nysfou ink?
Plus one for sublinova.
The worry with unbranded or re-branded inks is that even if the product remains available you are never sure that what is in the bottle is the same from one batch or another. Some online sellers just source the cheapest product available, bottle it and stick a label on.
