Has anyone had luck with the BlueWave 5 in 1 Mug Press? I haven't...
Chad
Re: Has anyone had luck with the BlueWave 5 in 1 Mug Press? I haven't...
Post by Chad »
Justin;153208 wrote:Have a search on here and you'll find a number of posts discussing the blizzard oven, that's what we use.
Forget the signworldz one, that's not what you need.
Bear in mind the size and how many mugs you can cook.
Received my BC01 yesterday and have just set it up.. have a few mugs in there now at 200 degrees [emoji1695]
As for the manual… [emoji533][emoji51]Image
[ATTACH=CONFIG]7288[/ATTACH]
20 minutes.
vB_ID:7288
vB_ID:7288
Chad
Post by Chad »
Justin;153443 wrote:[ATTACH=CONFIG]7288[/ATTACH]
20 minutes.
What does your thermometer say at that setting? Mines way higher [emoji28] did a gun test on a mug and it said 200 degrees, granted I didn’t check if the preheat light was off 🫣
Never checked it. I warm it to that temp and stick the mugs in, perfect consistency every time.
Chad
Post by Chad »
Justin;153445 wrote:Never checked it. I warm it to that temp and stick the mugs in, perfect consistency every time.
Bang on, thank you Justin!
Lol, I recognise that place, very nice
Chad
Post by Chad »
Justin;153448 wrote:Lol, I recognise that place, very nice
[emoji12]
Having just cooked my first set of 8 mugs, I’ve noticed an inconsistency in identical designs, both printed on the same sheet and cooked in the oven at the same time. Could this be overcooking? The right mug is noticeably more ‘faded’ and blacks not as deep. I upped the temp by around 5/10 degrees and had the same results again
Adding a couple of minutes may help but I can't see a logical explanation as to why these would be different. What mugs are you using and what type of wraps?
Chad
Post by Chad »
Justin;153452 wrote:Adding a couple of minutes may help but I can't see a logical explanation as to why these would be different. What mugs are you using and what type of wraps?
When upping temp a notch, this design ended up quite brown (right) compared to the previous cook (left) so I’m thinking maybe I need to drop the temp down and time up a touch. I’m using signsworld mugs (have always been great) and green wrapsImage
Yes, I wouldn't be upping the temp. When my unit was particularly cold I upped to 22 mins and it had no adverse effect.
