Greens are coming out blue
pjn11
Re: Greens are coming out blue
Post by pjn11 »
I have an Epson xp 352 running city ink express setup and paper when I print this green item it’s coming out more a blue please see pictures attached, any help will be greatly appreciated.
[ATTACH=CONFIG]7226[/ATTACH][ATTACH=CONFIG]7227[/ATTACH]
vB_ID:7227
vB_ID:7227
vB_ID:7226
vB_ID:7226
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
We need some more info.
When did the issue start?
What software are you printing with: photoshop, gimp etc.
Are you using an icc profile?
Can you post screenshots of the settings.
then the mug, paper and ink combo as well as pressing times will also make a difference.
Not so much in your case though.
pjn11
Post by pjn11 »
I’m using the latest version of photoshop I have the icc profile for the printer and city ink and I’m using the Cricut mug press.
it only started happening recently.
Mrteajunkie
Without seeing your settings i would say you may have changed something accidently.
A small change can make a massive difference.
pjn11
Post by pjn11 »
Lesson learnt must check ink nozzles are clean first
Thanks for your help was even thinking of buying a new printer.
[ATTACH=CONFIG]7228[/ATTACH]
vB_ID:7228
vB_ID:7228
