HS Tariff Code - Sending Coasters Abroad - Help
- UK Printed Mugs
Re: HS Tariff Code - Sending Coasters Abroad - Help
Hi all. We never send anything overseas but a customer needs to send some cork coasters and requires a "HS Tariff Code (Commodity code)". Does anyone send coasters and therefore knows the code and description that should be put please?
If no one comes back with the specific code there is a gov website checker which may help
Nothing comes up under a search for coasters but there is an "other" category under the search for "tableware" which might suffice.??
Can you not get the customer to arrange for a courier to collect from you? The problem will be transfered to him.
- UK Printed Mugs
These are coasters our customer already has and asked us the question this morning and we don't know the answer hence just wondering if anyone on here sends outside of the UK and would know the answer please.
- Mrteajunkie
- Has thanked: 5 times
- Been thanked: 3 times
It’s 441919 for the wooden ones I would imagine it’s the same for the rest unless cork comes under something else?
royal mail just gives these codes for coasters and another for cork placemats.
[ATTACH=CONFIG]7199[/ATTACH]
[ATTACH=CONFIG]7198[/ATTACH]
- vB_ID:7199
- Capture.jpg (9.85 KiB) Viewed 3218 times
- vB_ID:7198
- Capture.jpg (8.66 KiB) Viewed 3218 times
- UK Printed Mugs
That helped so much as I googled that code and found the one for cork coasters "44219090". Thank you, will pass onto customer.
- Mrteajunkie
I originally put that before i edited the post but couldn't find anything definite.UK Printed Mugs;152601 wrote:That helped so much as I googled that code and found the one for cork coasters "44219090". Thank you, will pass onto customer.
Stupid brexit.
