Hi from Durham
Re: Hi from Durham
I am Tom my wife and I have just started a little business doing some personalisation items so will probably be asking for advice. Do you guys have any recommendations for software. Currently we are using a cricuit 3 and using design space which has been working well. I have managed to get a mug press (a fairly decent one from the reviews I have found on here) a Jarin HF2200 but struggling to find software that will allow me to change to size of the paper and finally an Epsom xp225 already converted for sublimation. Any advice welcome
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 4 times
Re: Hi from Durham
Photoshop will be your best friend.
also a cricut is only able to use the DS software.
Cricut: I own one myself which is only used to cut edible prints and icing sheets.
Great for bedroom crafters but for business you need a better machine.
you will also find cricut support diabolical and the software crashing and messing up your saved designs after updates.
Don’t let that put you off though you have it already so make the most of it.
Re: Hi from Durham
Thanks for your reply, its very early days but is working so far, if it takes off then we will upgrade. We are literally just starting out so its a learning curve.Mrteajunkie;152518 wrote:Photoshop will be your best friend.
