Plastic business cards for sublimation ...
Re: Plastic business cards for sublimation ...
Thanks for that! I will have to see about getting some for a project....
Regarding subbing onto 760mic PVC cards, what time / temp / pressure settings would you recommend?knightweb;150697 wrote:Hi,
I've used the PVC cards below for sublimation, several hundreds
Printed both sides, they do bend and need to be weighted down after subbing, (and smell terrible)
I've probably got a few left over if you want some samples to try out, just let me know
Amazon
https://www.amazon.co.uk/gp/product/B07 ... UTF8&psc=1
HiBaldy,
I've just looked it up,170C for 20 sec, heavy weight after printing, when cool I printed the other side. I don't remenber the pressure, I've dated it just over 2 years ago. I had 6 or 8, which ever is the maximum, taped to an A4 sheet with teflon sheet covering them.
I've probably got a few left some where if you want half a dozen samples
Thanks for the info Kevin. - Less than I expected to be honest as I currrently do 0.2mm flexi plastic cards at 190c for 50s...so glad I asked:+)
Thanks too for the sample offer, although there should be 100 landing today...and if I don't get any joy, I can always use them for foil stamping jobs.
- Mrteajunkie
- Has thanked: 5 times
- Been thanked: 3 times
Would one of you be kind enough to post an image of a pressed card?
I thought about making some myself but my experience with the thin plastics wasn’t great.
[ATTACH=CONFIG]7134[/ATTACH]Mrteajunkie;152198 wrote:Would one of you be kind enough to post an image of a pressed card?
This is one of the 0.2mm flexi ones we had a play with - available from TTP (https://www.thetransferpress.co.uk/plas ... 2x32864199).
No subbed 760mic cards to photograph...yet
- vB_ID:7134
- IMG_20230324_132830.jpg (95.99 KiB) Viewed 50 times
[ATTACH=CONFIG]7135[/ATTACH]Mrteajunkie;152198 wrote:Would one of you be kind enough to post an image of a pressed card?
Good vibrant prints...and no need to weight down after pressing either.
No subbed 760mic (credit card thickness) cards to photograph...yet
- vB_ID:7135
- IMG_20230324_132830.jpg (92.12 KiB) Viewed 50 times
- Mrteajunkie
Even better they are on my doorstep. Only 5mins away from meBaldy;152201 wrote:[ATTACH=CONFIG]7135[/ATTACH]
I’ll have to grab some Monday these will be great for promotional use.
Can I ask where you get your clips and the punch to make the holes?
I did spot your location and wonder if you were close.Mrteajunkie;152202 wrote:Even better they are on my doorstep. Only 5mins away from me
Regarding the bits...
The clips came from ebay, although I suspect the seller made an error on the pricing as they're now charging about 10x the price I paid. - Plenty of choice from other sellers though:
https://www.ebay.co.uk/sch/i.html?_from ... s&_sacat=0
- I have also since found clips on the ID Card Centre website (https://www.idcardcentre.co.uk/search?s ... 0Fastening)
As for the punch, another ebay purchase.
https://www.ebay.co.uk/itm/203842353112
13x3mm hole. Works with the thicker 760mic cards too.
