Manual
Nelixuk2003
Re: Manual
Post by Nelixuk2003 »
Hi all
Does anyone know where I might get my hands on a manual for an Adkins Heat Press, or a technical sheet relating to codes that the machine might display, i believe these machines also 'Beep' when there is an error so is there any info as to how to translate the beeps/codes?
I'm new to all this and have been offered a press but it has an intermittent 'HF Code Beep' fault, just trying to work out if its worth getting and repairable. I know Adkins is no longer around but I'm handy with electronics down to component level so happy to take a soldering iron to the board if needed in order to repair, just need to be able to diagnose from the beeps/code as a starting point.
Thanks in advance
Re: Manual
Contact Adkins direct with the model number and they will be able to send you everything you need
Nelixuk2003
Re: Manual
socialgiraffe;151640 wrote:Contact Adkins direct with the model number and they will be able to send you everything you need
I have tried emailing Adkins and after a week I have received no response, I was hoping that someone may already have this information that might be willing to share it.
I'll try emailing them again but as they are apparently no longer trading.... or will cease soon, I do not hold out much hope.
Re: Manual
Try speaking to Xpres.
Nelixuk2003
Re: Manual
Justin;151650 wrote:Try speaking to Xpres.
Cheers, email just sent, awaiting response
Nelixuk2003
Re: Manual
Well, after a week or more and I have not received a response from either Adkins or Xpres, would anyone have this information that they might be willing to share?
Re: Manual
Adkins no longer exist. Xpres bought them.
No point trying to contact Adkins.
Phone Xpres, much easier to ignore an email.
Re: Manual
Ok, I'm not an Adkins user so don't know if the following will be of any help, but I've been able to find links for some Adkins Heat Press manuals that may be useful ...
BETA MAXI A2
https://data2.manualslib.com/pdf7/241/2 ... ec09781e94
BETA MAJOR
https://data2.manualslib.com/pdf7/166/1 ... 9319f41f8e
HOBBY JACK
https://data2.manualslib.com/pdf4/95/94 ... 9a6238cd98
STUDIO 'EZ' AUTO CLAM
https://data2.manualslib.com/pdf7/166/1 ... 394bfcc8d5
STUDIO PLATE
https://data2.manualslib.com/pdf7/181/1 ... 10330cecff
