I tried iPhone 16 the results were a little off [ATTACH=CONFIG]7017[/ATTACH] :biggrin:UK Printed Mugs;151403 wrote:Fantastic - just got my invite to Dall-e!! So needing a coffee my very first image generation text was "giant mug of coffee in field of flowers, Picasso" which resulted in the following - very impressed!
[ATTACH=CONFIG]7016[/ATTACH]
Anyone using AI (Artificial Intelligence) to produce unique designs? ...
- Mrteajunkie
- Has thanked: 6 times
- Been thanked: 4 times
Re: Anyone using AI (Artificial Intelligence) to produce unique designs? ...
- vB_ID:7017
- 7C0F2044-DF5F-4FA4-AC11-BEE2250A6BC2.jpg (17.33 KiB) Viewed 349 times
I've got to admit that I wasn't that impressed with DALL-E considering all the hype. Here's a few images it produced that were near to the prompts ...
[ATTACH=CONFIG]7020[/ATTACH]
Lakeland Terrier oil painting, detailed
[ATTACH=CONFIG]7021[/ATTACH]
rottweiler hugging rabbit, award-winning
[ATTACH=CONFIG]7019[/ATTACH]
warrior teddy bear, screenshot from game of thrones
- vB_ID:7021
- DALL?E 2022-09-29 16.19.57 - rottweiler hugging rabbit, award-winning.jpg (10.94 KiB) Viewed 349 times
- vB_ID:7020
- DALL?E 2022-09-29 16.16.46 - Lakeland Terrier oil painting, detailed.jpg (19.45 KiB) Viewed 349 times
- vB_ID:7019
- DALL?E 2022-09-29 16.22.29 - warrior teddy bearr, screenshot from game of thrones.jpg (14.04 KiB) Viewed 349 times
** IT JUST GETS BETTER! **
Now you can use DALL-E and STABLE DIFFUSION on this site absolutely FREE and it's dead simple to use!
https://playgroundai.com/
You can Upscale any image and you can generate images in blocks of up to 4 variations at a time. In fact, you can just keep clicking the 'Generate' button as many times as you like as there doesn't seem to be an upper limit on the number of generations!
Here's one of the first images I tried: 'rottweiler wearing a crown and dressed in ermine, photorealistic' ...
[Click to enlarge]
[ATTACH=CONFIG]7023[/ATTACH]
The Upscaled version is an incredible 4096 x 4096 pixels!
Go on, fill yer boots! :biggrin:
- Register for free (I just signed in with Google)
- Type in your Text Prompt
- Pick a Model (DALL-E or SD)
- Select a filter from the list, or 'none'
- Click on the 'Generate' button
[Click to enlarge]
- vB_ID:7023
- rotty_crown_small.jpg (10.55 KiB) Viewed 349 times
