Blizard Oven
Re: Blizard Oven
Hi guys. How long for 16mugs in Blizard oven please?
I have 8 mugs on each try.
Thanks i advance
Thanks i advance
Re: Blizard Oven
In this weather and depending on your mug coating, inks and paper I would say between 16 minutes and 20.
If you do not know I think the best way is to put 18 mugs in the oven.
At 16 minutes take ONE out and see what it's like. If good take them all out. If not leave them 1 minute ish and take another one out. This way, you will only "ruin" two mugs and not 16.
Re: Blizard Oven
Epson inks.
S racer paper
Orca mugs.
I will try that tomorrow.
S racer paper
Orca mugs.
Re: Blizard Oven
Orca 10oz about 22 - 23 mins for standard text.
25 - 26 mins for full top to bottom 11oz mugs.
160 degrees C
160 degrees C
Re: Blizard Oven
Even when its only 8 mugs Gooner?Orca 10oz about 22 - 23 mins for standard text.
160 degrees C
Re: Blizard Oven
I got 16 mugs in. Full wrap print. 160C????GoonerGary;151283 wrote:Orca 10oz about 22 - 23 mins for standard text.
160 degrees C
Re: Blizard Oven
What's the best wraps for the oven? I use green ones but those get ink transferred to the rubber and are ruin next mugs.
What do you guys are using?
Re: Blizard Oven
We use the green wraps but use thicker paper from In Experts and get no ink transfer
Re: Blizard Oven
I usually print 12 per batch and keep the temperature low. S Race or TruePix papers and Sublinova Smart.Paul;151285 wrote:I got 16 mugs in. Full wrap print. 160C????
