MDP Orca mugs
harlequeen
Re: MDP Orca mugs
Post by harlequeen »
Hi
Is anyone using MDP Orca mugs and finding that they 'blow' certain colours? I have been using these mugs as MDP is close by and my other supplier has been out of stock. When I print with certain colours as the focus, I can see that there is blow out on particularly vibrant colours - red, deep blues and yellow. I am using a sawgrass printer and have been printing mugs for about 8 years, but only seem to get this with MDP Orca.
Any advice?
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Re: MDP Orca mugs
Post by Mrteajunkie »
harlequeen;151174 wrote:Hi
Any advice?
Its all I use (10oz version) and not having any issues and just had another batch delivered yesterday without issues also.
JMugs
Has thanked: 10 times
Been thanked: 10 times
Re: MDP Orca mugs
Post by JMugs »
Interesting and intriguing. I use MDP and not noticed an issue. I shall have a really close look and report back if I note an issue.
Janners.
harlequeen
Re: MDP Orca mugs
Thanks, I've been using them for a good while now, but it seems to be an issue only on vibrant colours.
Mrteajunkie
Re: MDP Orca mugs
harlequeen;151294 wrote:Thanks, I've been using them for a good while now, but it seems to be an issue only on vibrant colours.
Can you post a picture?
Scott
Re: MDP Orca mugs
Post by Scott »
I printed quite a few Orca Mugs from MDP a while ago and found that if i slightly overcooked or removed the paper before they were totally cold i had exactly the same issue as what you are explaining
Mrteajunkie
Re: MDP Orca mugs
Scott;151555 wrote:I printed quite a few Orca Mugs from MDP a while ago and found that if i slightly overcooked or removed the paper before they were totally cold i had exactly the same issue as what you are explaining
Dunk them in warm/hot water straight from the press and remove the paper after the dunk.
it stops the sub process and any issues.
Users browsing this forum: Google [Bot] and 6 guests
