The same way you print large banners, on an Eco solvent or UV printer with a proper block out scratch resistant substrate specifically designed for the job, or on a material that is laminated afterward.UK Printed Mugs;142686 wrote:Question - How do you print onto the mini banners? Are they polyester material so can sublimate or just pop into inkjet printer....Hmmm
There might be a substrate that you can ink jet onto, but it’s not going to be scratch resistant and if the material has the tensioning flexibility that you need.
Getting something for sublimation will end up costing more than doing it “properly”
