halogen oven
Re: halogen oven
I just resurrected my old halogen oven. I wonder if anyone remember temperature and times for them? it fits 4 mugs.
- vB_ID:6888
- 61mTJkLwxoL._AC_SL1500_.jpg (91.69 KiB) Viewed 20 times
Re: halogen oven
Webtrekker will be the knowledge on these machines
Re: halogen oven
I worked it out already
Re: halogen oven
socialgiraffe;150466 wrote:Webtrekker will be the knowledge on these machines
Sadly, I haven't used mine in a long while now. I remember though that I used to get more consistent results with no more than 2 mugs in the oven at a time. The main reason for me using an oven was to get more coverage on the mugs.
Re: halogen oven
i get 5 of them at the time
- vB_ID:6890
- IMG_0935 (1).jpg (50.92 KiB) Viewed 20 times
Re: halogen oven
Just out of curiosity, what temp/time do you recommend for multiple mugs?Paul;150476 wrote:i get 5 of them at the time
Re: halogen oven
About 180c for around 15 minutes
Re: halogen oven
“About” & “Around” the only true signs to know a proper dye subber by [emoji16][emoji16][emoji16]Paul;150492 wrote:About 180c for around 15 minutes
Re: halogen oven
Very true! As if print solid colours those values will change 100% ��
Re: halogen oven
Also, there is no digital temp or time gauge. Only manual spinning knoobs. So they are not very accurate anyway.
