SEFA vs Stahls?
gazfocus
Re: SEFA vs Stahls?
Post by gazfocus »
We are looking at buying an additional heat press for doing T-shirts and I’m struggling to decide between the Hotronix IQ and the SEFA Rotex Pro V3. The SEFA is coming out at about £300-400 more than the stahls but I don’t know if it’s a better press.
Curious to hear if anyone has the SEFA and what your opinions are if you have one.
pw66
Re: SEFA vs Stahls?
Post by pw66 »
Beware of auto open heatpresses for sublimation. When the electromagnet releases it can cause the transfer to jump, leading to ghosting (on some presses).
Never used either presses, but I gave up using Hotronix in favour of Pressmech. For the cost of the SEFA you could get a Pressmech pneumatic press or 2 of the manual ones.
gazfocus
Re: SEFA vs Stahls?
Post by gazfocus »
pw66;150370 wrote:Beware of auto open heatpresses for sublimation. When the electromagnet releases it can cause the transfer to jump, leading to ghosting (on some presses).
I’ve not heard of pressmech before but they look like very ghetto…will research them though. My main requirement is to have something programmable so we can have a setting for htv, a setting for coasters, keyrings, etc, and also something that can feed T-shirts properly.
The sefa is very soft at opening from the videos I’ve seen so eliminates the judder when opening, though I do get your point about that and is one reason I’ve discounted the Galaxy presses.
pw66
Re: SEFA vs Stahls?
Post by pw66 »
gazfocus;150371 wrote:I’ve not heard of pressmech before but they look like very ghetto…will research them though. My main requirement is to have something programmable so we can have a setting for htv, a setting for coasters, keyrings, etc, and also something that can feed T-shirts properly.
I personaly stear clear of anything programmable - far to much to go wrong, and potentialy expensive to repair if it does.
Unless you have a turnover of inexperienced staff is there any real benefit to having programable settings? It might save a few seconds but you still have to wait several minutes for the temperature to adjust which outweighs the time saving.
You are right that the SEFA is a very different animal to the Galaxy presses. There was a used SEFA on ebay recently - it might still be there.
bubbleimages
Re: SEFA vs Stahls?
Post by bubbleimages »
We have a SEFA auto-open, and it has been fantastic for the past 2 years since getting it from Xpres, lovely machine.
