Okay. I have seen videos on YouTube where they mix Polycrylic and water to make a spray solution, can the water be substituted for 99% Isopropyl Alcohol to dry faster?Or will it destroy the Polycrylic solution.
Also has anyone tried the oil based Polycrylic rub solution? did it work better than the water based, same or not at all? For sublimation image transfer of course.
Thankyou.
Polycrylic water mix sustitute, and oil based polycrylic rub question
