Heat Press pad material help
Willk24
Re: Heat Press pad material help
Post by Willk24 »
I’m sublimating a hoodie that requires thread on to the lower platen for best results. The issue I am having is the that rubber material is to grippy and thus it a pain to thread the hoodie. Does anyone know of a material that has:
  • A decent amount of compression and bendability to it
  • Whilst also being able to with stand 200 degrees C
  • And sooth with zero tack so the hoodie will glide on
I have tried covering the rubber mat I already have with Teflon and heat resistant tape but the constant putting on and taking off cases issues this I would like for find something that I don’t need to think about.
Mrteajunkie
Has thanked: 5 times
Been thanked: 3 times
Post by Mrteajunkie »
Teflon sheets or Teflon pillows are your friend here.
Target transfers sell covers for both the bottom and top platens. I have a lower cover on one of my heat presses and that really helps with this sort of thing.
as Simon said - Target transfer is your friend
[ATTACH=CONFIG]6823[/ATTACH]
vB_ID:6823
vB_ID:6823
Users browsing this forum: Amazon [Bot], Bing [Bot] and 4 guests
