Colour changing after wash of shirt
Tablo
Re: Colour changing after wash of shirt
Post by Tablo »
I’ve had a couple designs(albeit not perfect pressed) have issues in being washed in one home machine but the same designs have had no issues when they were washed on another machine. What are the factors that causes colour fading especially from a single wash in certain washing machines. Is the quality of the pressing? The quality of the printer used or the water usage or temperature setting. Lost as I don’t know why my prototype designs are faring badly against this particular washing machine yet decent against another.
Are the shirts 100% polyester?
Fletcher
Post by Fletcher »
Hi, Im guessing your using sublimation?
So a few things can cause colour to fade after a wash.
Have you used sublimation ink to start with?
Sublimation works best on white 100% polyester clothing. Using other colours or not 100% clothing means the colours wont hold well, and can fade.
Hot washing can cause colours to fade. Tho most people have an eco 30 or 40 degree wash on the machines many still wash hot.
logobear
Post by logobear »
Tablo,
you need to tell us a lot more about your setup
Printer
ink set
paper/media
garment - type, colour fabric
temperature & time of pressing
We have all been along the learning curve......
Tablo
Post by Tablo »
Fletcher;149986 wrote:Hi, Im guessing your using sublimation?
My system was pressing printed StarCraft heat transfer vinyl with an admins beta maxi heat press. I dont think that counts as sublimination. Material was 100 percent cotton.
Tablo
Post by Tablo »
pisquee;149982 wrote:Are the shirts 100% polyester?
100% cotton
Tablo
Post by Tablo »
Printer was an hp ink desk canon not sure on the model off the top of my head I’ll add to this after I can confirm. The printing material was StarCraft heat transfer vinyl. Garment was white 100 percent cotton at 200gsm.Pressed at around 375 degrees. Tim’s if pressing was August I think . Middle of august.
Tablo
Post by Tablo »
logobear;149987 wrote:Tablo,
Printer
ink set
paper/media
Tablo
Post by Tablo »
Tablo;150026 wrote:Printer was an hp ink desk canon not sure on the model off the top of my head I’ll add to this after I can confirm. The printing material was StarCraft heat transfer vinyl. Garment was white 100 percent cotton at 200gsm.Pressed at around 375 degrees. Tim’s if pressing was August I think . Middle of august.
Printer was hp envy 6234 actually.
pw66
Post by pw66 »
So you were using inkjet printable transfer vinyl?
Inkjet transfers never last as long as some other methods. There is usually some fade after the first wash. They are ok for short term use.
There are several probable reasons.
- most inkjet vinyls work best with pigment based ink, not dye based ink. Dye ink is more susceptible to washing out (don't confuse 'dye' ink with 'dye sublimation' ink)
- it is best to let the transfer dry fully (preferably overnight) before pressing
- most inkjet vinyls recommend that you don't wash for 24 hours after pressing
- inkjet transfers are very susceptible to washing temperature. Cool, fast and inside out is best.
