Photo slate sublimation problem
gouna
Re: Photo slate sublimation problem
Post by gouna »
[FONT=&amp]Hello[/FONT]
[FONT=&amp]
[/FONT]
[FONT=&amp](excuse me I'm French).[/FONT]
[FONT=&amp]I have some problems with my photo slates[/FONT]
[FONT=&amp]I use the glossy photo slates, but the rendering seems mat (except on the edges where it is very glossy) :[/FONT]
[FONT=&amp]Image[/FONT]
[FONT=&amp]
[/FONT]
[FONT=&amp]In addition, the rendering has an "orange peel" effect :[/FONT]
[FONT=&amp]
[/FONT]
[FONT=&amp]Do you have an idea?[/FONT]
[FONT=&amp]
[/FONT]
[FONT=&amp]My settings:[/FONT]
[FONT=&amp]1) tension foam[/FONT]
[FONT=&amp]2) Poly120 paper[/FONT]
[FONT=&amp]3) slate upside down[/FONT]
[FONT=&amp]4) protective sheet[/FONT]
[FONT=&amp]5) medium pressure, 180 ° Celcius and 420 seconds[/FONT]
[FONT=&amp]Also, sometimes I have cracks only on the sublimable face :[/FONT]
[FONT=&amp]
[/FONT]
[FONT=&amp]Thank's ![/FONT]
gouna
Post by gouna »
We see the "surface defect" on the blank slate. I guess the problem is the coating.
Moreover, on my digital alarm clocks, I also have this kind of stains, a bit as if the fibers of the paper melted in the coating (on aluminum plates, 30 sec at 180 degrees, very low pressure = improves things!)
I spotted this problem on the internet, we note the difference in quality between the 2 types of coating ...
[ATTACH=CONFIG]6798[/ATTACH]
vB_ID:6798
vB_ID:6798
if you use foam, why do you flip them up side-down?
gouna
Post by gouna »
Paul;149945 wrote:if you use foam, why do you flip them up side-down?
hello, I use the foam mat to mark the edges well
