Anyone make signs 2mtr X 2mtr on 5 or 10mm foamex ONE PIECE
Customer wants one piece!
I need a 2m x 2m sign ANYONE?
Re: I need a 2m x 2m sign ANYONE?
Foamex type materials are available in upto 3m x 2m sheets - usually just in white in larger sheets - so you should be able to find someone who can help.
Unless your artwork lends itself to being applied in smaller sections the hard part will be finding someone with a 2 metre wide printer.
Here is a link to help you with quoting -
https://www.plastock.co.uk/foam-pvc-palight-white-sheet
- Mrteajunkie
- Has thanked: 5 times
- Been thanked: 3 times
- UK Printed Mugs
Yes 2m a bugger in both dimensions and haven't found anyone that huge for one complete board. For foamex printing we always use https://www.pixartprinting.co.uk/wide-f ... s/acrylic/ - They also have 25% off first order and free delivery. Last display stand we did at NEC used all their boards and very impressed as always. You might have to compromise with client and get two lots of 200cm x 100cm
