Epson 1400 (Chromablast) Printer blocked Dark Cyan
JSR
Re: Epson 1400 (Chromablast) Printer blocked Dark Cyan
Post by JSR »
If it's a fault you can't easily fix yourself, it's worth reading up on your legal rights under the Sale of Goods Act.
Typically your contract of sale is with the company you bought from, not the manufacturer. Legally the manufacturer doesn't have to lift a finger to help you - that includes Ricoh, Epson, or anyone - unless you bought direct from the manufacturer (because then they'd be the retailer). If you go to the manufacturer off your own back, the seller can wash their hands of the situation so it's important to go to the seller at the first instance.
Legally, the seller cannot insist that you go the manufacturer. They can advise you that it may be quicker to do so, but you're not obliged to do this. You are within your rights to insist that the seller deals with the problem. Indeed, this is what you should do because your sales contract is with the seller.
A warranty is not essential. A warranty is in addition to your legal rights, it does not replace your legal rights. It can only enhance your legal rights, not diminish them. Under the Sale of Goods Act, you have certain rights for up to six years from purchase (five years in Scotland). If your printer is 12 months and 1 day old, don't be put off by the seller saying "it's out of warranty" - because, legally, that doesn't wash. This applies even if you don't have a warranty.
Some rights vary depending on whether you bought as a consumer or as a business. If you bought from an individual (someone selling off a printer on ebay as an individual) or if you bought a second-hand unit, then your rights are severely diminished. In all circumstances you should read up on the Sale of Goods Act to learn what your rights are.
It's up to you how you want to use your rights. If your printer is 3 years old and it's showing signs of problems, then it may be time to replace it anyway because it may be deemed to have lasted for a "reasonable time" and any redress you get may be too minor to justify your efforts.
We don't get too much help in this country, but we do have legal rights. If you need them, use them. But use them properly. ;)
AdamB
Post by AdamB »
Thanks for this - I have been 'brushing up' on the Sales of Goods act this evening ........... great info, appreciated.
just4yougifts
Post by just4yougifts »
Hello,
I have been reading up on this post and we may have the same problem. We can't print dark Cyan either. It has been like this for a while now and mulitiple flushes hasn't sorted it out.
We have an Epsom 1400 but not using Chromablast.
Should I try use the advise here to fix it or could our problem be different?
Many Thanks
Lynsey
Yes, it's a standard process for any bulk feed system using dye ink, sublimation ink, chromablast etc etc.
just4yougifts
ok, I will give it a go.
thanks
Stitch Up
Post by Stitch Up »
Try this from Lyson
Never used it myself.
or send the printhead to me
Printer Jockey allows you to target clean from the selected nozzle and no other.
I think I go for Magic bullet in case of blockage in future :) looks good and inexpensive.
You mustn't assume it's a blockage in the printhead, hence the reason for testing with the genuine cartridges. Going to the extreme of removing the printhead or using printhead cleaners on Epson printers can be an expensive and laborious process if the issue is not printhead related.
good point ;)
accdave
Post by accdave »
Paul;14819 wrote:I think I go for Magic bullet in case of blockage in future :) looks good and inexpensive.
I tried that Magic Bullet thing on a blocked 1400. Must not have been a live round, it fired a blank !!
