Making the right choice!
danlad
Re: Making the right choice!
Post by danlad »
What is the cost like per print or the yeild from each cart? BMS reckons there is not to much in it compared to a CIS set up. What is your thinking Justin?
As a direct comparison I would have thought the costs are similar. Members report the Ricoh being better for not having to carry out head cleans etc. which would save ink but the initial ink cost is higher than Artainium etc. so this probably evens out. The Ricoh would be a good solution for you if it has to stay on the stand, no bottles to fall off and a very neat operation.
danlad
Post by danlad »
ok, thanks for the advice Justin.
danlad
Post by danlad »
Where can the inks be bought for the Ricoh GXe3300?
Several of the authorised suppliers, us included, sell the carts for the GXe3300. Sawgrass RRP is £40 +vat per cartridge.
danlad
Post by danlad »
Is that the make of the ink carts Sawgrass Martin?
No, the cartridges contain SubliJetR inks (the R at the end is important as it signifies the Ricoh printer).
I think most suppliers like us refer to them as SubliJetR cartridges - they are supplied by Sawgrass.
