Hello,
I have printer Ricoh 3110dn. Today when I printed one photo, photo came out totaly strange (not clear). This is first time for me and I tried to change setting once again but result is the same.
I use Sublisplash colors, I have ICC profile and I'm working in Photoshop. I also tried to change setting: IMAGE - MODE - RGB or CMYK but result is the same. I also do nozzle check.
Does anyone have idea what to do and which setting I must check once again? I must finish one order so I will be happy for your help!
Regards,
Anze
PROBLEM with PRINTED PHOTO - SG3110 (photo not recognizable)
Re: PROBLEM with PRINTED PHOTO - SG3110 (photo not recognizable)
- vB_ID:6471
- PS.jpg (69.69 KiB) Viewed 289 times
- vB_ID:6470
- PHOTO2.jpg (87.1 KiB) Viewed 289 times
- vB_ID:6469
- PHOTO1.jpg (97.41 KiB) Viewed 289 times
- Mrteajunkie
- Has thanked: 5 times
- Been thanked: 3 times
What’s wrong with It?
until pressed it will not look anything like the original picture.
I tried smaller photo but it's not ok.
[ATTACH=CONFIG]6472[/ATTACH][ATTACH=CONFIG]6473[/ATTACH]
[ATTACH=CONFIG]6474[/ATTACH][ATTACH=CONFIG]6475[/ATTACH]
- vB_ID:6475
- IMG-0304.jpg (86.23 KiB) Viewed 289 times
- vB_ID:6474
- IMG-0303.jpg (83.34 KiB) Viewed 289 times
- vB_ID:6473
- IMG-0302.jpg (85.26 KiB) Viewed 289 times
- vB_ID:6472
- IMG-0301.jpg (85.95 KiB) Viewed 289 times
Dynamic Grafix
It could be the bit rate. Under the area where you changed from RGB to CMYK, you have options for 8 bits, 16 bits and 32 bits.Strmecki;146507 wrote:Hello,
Regards,
Anze
If this is a screenshot from a new iPhone, they're now 16 bit which can cause this issue. Change it to 8 bit or vice versa for something different thing to try.
