Heat Press temp controller - needed
Help in finding new products.
John G
Re: Heat Press temp controller - needed
Post by John G »
[ATTACH=CONFIG]6455[/ATTACH]
Hi All,
Just wondering whether anyone had a spare temp controller kicking about, from an old heat press, that they could sell me - my heat press is on its last legs and I don't really want to replace it. Or if anyone can point me in the right direction for new spare parts as the timer has gone as well lol.
Cheers John
vB_ID:6455
vB_ID:6455
temp controller.jpg (91.63 KiB) Viewed 691 times
Mrteajunkie
Has thanked: 6 times
Been thanked: 4 times
Post by Mrteajunkie »
What make and model press is it ?
different presses use different wiring and one may be say 3amp and your may draw 6 amps.
as soon as you plug it in it will go pop unless it has enough output and assuming the wiring is right?
https://www.ebay.co.uk/itm/313214593035
John G
Post by John G »
Thanks for that - Its an old Coralgraph press but it doesn't have a make/model badge. I've seen that on ebay but wanted a like for like one, so it would be compatible. I've contacted Coralgraph but haven't had a responce.
