Hello,
what epson printer do people recommend for mug printing? the epson et 2700 i currently have seems very unreliable.
Printer recommendation
iantaylor197
- Mrteajunkie
- Has thanked: 5 times
- Been thanked: 3 times
Re: Printer recommendation
Why is it unreliable?iantaylor197;145393 wrote:Hello,
I have the et-2750 and it’s a cracking printer.
It’s not the fastest but lovely clear prints and perfect for what I use it for.
iantaylor197
We have two one is running fine. But one we have is one problem after another. It keeps printing ting dots on the paper which transfers onto the mug, do you have any idea what is causing it? have you had any problems along the same lines?
Please see pics attached.
As i say running exact same settings - paper - inks as our other ET 2700 which prints perfect.
Thanks[ATTACH=CONFIG]6409[/ATTACH]
- vB_ID:6409
- Mug.jpg (75.88 KiB) Viewed 121 times
- Mrteajunkie
Have you done a nozzle check and clean?
could be something stuck on the head, and it’s spraying ink like when you put your finger over the hosepipe rather than laying it down where it should be.
iantaylor197
Yes done all the usual cleans. First few prints will be fine but after 3 or 4 it starts doing it.
