new machine - help
grantsmith82
Re: new machine - help
Post by grantsmith82 »
Hi all
i just got my first heat press machine but have a few concerns / questions.
when opening the box the base plate is all scratched (see attached photos) however came with a cloth that appears to go over.. other than cosmetic / and thinking a new machine shouldnt looks like this
is it going to have any detrimental affect on use? (see photos)
secondly on the swing away press there is a foam piece that is starting to peel away. Should this be doing that? (see attached photos) or is this protection cover for transportation that i can peel off ?
Grant
vB_ID:6387
vB_ID:6387
WhatsApp Image 2020-09-29 at 12.51.00.jpg (37.61 KiB) Viewed 8 times
vB_ID:6386
vB_ID:6386
WhatsApp Image 2020-09-29 at 12.51.05.jpg (25.2 KiB) Viewed 8 times
vB_ID:6385
vB_ID:6385
WhatsApp Image 2020-09-29 at 12.51.06.jpg (26.57 KiB) Viewed 8 times
vB_ID:6384
vB_ID:6384
WhatsApp Image 2020-09-29 at 12.51.05 (1).jpg (33.61 KiB) Viewed 8 times
vB_ID:6383
vB_ID:6383
WhatsApp Image 2020-09-29 at 12.51.01.jpg (35.99 KiB) Viewed 8 times
vB_ID:6382
vB_ID:6382
WhatsApp Image 2020-09-29 at 12.51.02.jpg (38.07 KiB) Viewed 8 times
vB_ID:6381
vB_ID:6381
WhatsApp Image 2020-09-29 at 12.51.03 (1).jpg (33.44 KiB) Viewed 8 times
pw66
Post by pw66 »
That foam pad should be firmly glued to the lower platen, not hanging from the top platen....
Send it back for a full refund.
How did you pay?
